According to one compatibility source, it says the Alpha PAL8045 Heat Sink will not fit an ECS K7S5A version 3.1 motherboard due to version 3.1 having larger caps.
I carefully measured the surrounding objects on my motherboard comparing it to the PAL8045 drawing measurements and found no such issues.
Perhaps there are 2 versions of the 3.1 motherboard, one having larger caps?
Anybody know for sure?
Ira
P.S. (This is not a thread to say how much you love/hate the K7S5A board )
i have an 8045 on my K7S5A although unsure of the rev number. if you tell me where it is silkscreened, i will take a look as long as its not on the backside of the board.
The Rev 3.1 number on my board is at the back (I/O Connector) corner of the motherboard where the PCI slot furthest from the Power Supply is located and is on the component side.
___I have installed the 8045 on the first rev’s as well but the 3.1, I do not have a clue. I believe Alpha listed the first rev’s as being non-compatible with the ECS K7S5A boards. I purchased Alpha Pal 8045’s for the ECS boards after seeing two individuals that had installed them successfully on their own K7S5A’s during the time of initial release. I posted your question in a thread regarding the Rev 3.1’s in the ECS 2002 forums over at OCWorkbench. Just keep up with the link provided and you should hopefully have your answer in a day or two.
Thanks for posting that. I don't spend that much time on the OCWorknbench board as I don't really believe in overclocking (other than for schmoo testing). Nevertheless, they are a wonderful forum resource on the inner workings of boards, just as this is for Home Theater.
As a followup, I got my PAL8045 heatsink and installed it with no problems on my 3.1 board.
I'm using a PAPST 8412 NGMLV 80cm fan. My CPU temperature is hovering at about 52 to 56 degrees C for the Socket A sensor and an Athlon 1800 XP. Do you know if that seems typical, or do I need better thermal paste?
