1 - 2 of 2 Posts
I don't really understand a lot of the numbers and have been considering Temple Audio's Bantam Gold.
http://www.templeaudio.net/bantamgold.html
I've just discover this though and wondered whether it might be a better option.
http://www.bkelec.com/HiFi/ClassD/ClassD.htm
Amp will be driving 90db 8ohms Cambridge Audio S30s - mailny nearfield listening in a 11'x11' bedroom filled with furniture.
Which would you buy out of these two or do you know of an even better D Class / T Class?
I'm looking for something lovingly designed and engineered, prefererably though not necessarily by a small British company.
Originally Posted by MusicAndWine  /t/1471504/does-this-b-k-electrics-pear-drop-d-class-look-well-designed-and-built#post_23283355
actually your speakers are easy to drive ( 90db), based on spec even bantam should able to drive your speakers. If you're looking better class d amp try hypex ncore, but you must have DIY skills.
1 - 2 of 2 Posts
