Status
Not open for further replies.
1 - 5 of 5 Posts
Both the Samsung SIR-T151 and the Sylvania SRZ3000 have a sync issue with the X1 v3.8 firmware. The temporary fix was to revert to v3.6.
Does the new version address this issue?
Do you need to select the new sync option through the menu?
Are there any side effects to using the new option such as the DVD player no longer syncing correctly?
Why don't you just try?
It only takes a few minutes and you also get the extra 1000 hours on the lamp counter.
I don't have an over the air set top box, but I had sync problems with my Panasonic DVD-CP72 going through the VGA port. The new firmware did fix it, so you absolutely should try it.
Mine would always resync whenever the screen was all white, like if someone points a flashlight directly at the camera. With the new firmware there is a checkbox in the settings that says something about sync threshold. I checked it and haven't had a problem since.
1 - 5 of 5 Posts
Status
