I would like to know how many people out there that receive HDTV via Cable(not DBS) can tell a noticeable different between HDTV via cable Vs. via OTA.
Here in Tampa FL most people receive HDTV via cable that is provided by Bright House Networks. One of the engineers has been so adimate that they don't reshape or re-compress in any way, that they have had Tours in Orlando to show some of the non believers that they don't own any re-shapers.
Personally I have done a A/B comparison between Cable and OTA, utilizing an E86 D* receiver via component to my Mitsu ws55711. Vs BHN Pace hd550.
I have to say that I can not tell a difference.
I have also captured the QAM stream and the OTA stream to my hard drive and the bit rates are the same.
Here is the thread over at TampaHDTV.com
http://www.tampahdtv.com/modules.php...iewtopic&t=186
Here is a post from that thread, from the BHN associate.
Are we lucky here in Tampa? What is your experience with your local cableco?
First, the home show guy is (looking for a polite term here...) wrong. BHN passes the signal to the settop in the format it's presented to us. Then, depending on what box you have, the output resolution is determined. If you have a S/A 3100HD, everything coming out the component outputs is 1080i. If you have a Pace 550HD, then you have the choice to specify output resolution at 1080i, 720p, 480p, or 480i, or just let whatever resolution the broadcaster adopted pass through. Regarding the Stereophile Guild to Home Theater article, it's full of misleading assertions. First, every cable company, and indeed, almost every cable operation in the country is different -- you can't paint them all with the same brush. Heck, I think the differences in BHN in Central Florida vs. Tampa alone would prove my point. Secondly, does BHN remove bits from the HD stream -- yes. Because the 8VSB modulation scheme is intended for OTA broadcasts, its designed to deliver an intact signal despite the "challenging" environmental conditions the signal must traverse. QAM modulation, conversely, is designed to travel in the protected path a Hybrid Fiber Coax cable plant provides. Therefore, the robust error correction data the 8vsb signal sends along with the video/audio is unnecessary, and even more so, unused at the receiving end. The short version is that we don't need to send a full 19.4mbs to deliver the exact same signal -- the bits that are the signal come through untouched. We've been accused of compressing signals time and time again. All I can say is that it isn't true. We don't own any compression equipment. Heck the other day I was trying to get some locally produced video encoded to put it on our iControl platform, and I had to send the tape to inDemand to get them to pitch it back via satellite. I finally convinced the Orlando High Definition Society folks that we don't compress by giving them a tour of our headend. We can't do it, because we don't have the equipment to do so. Period. The final thing the Stereophile guide complained about was a device that performs "rateshaping". While there are companies trying to sell these to us, we haven't bought any. |
