Dolby Digital help: Samsung DVD-1080P7 to Pioneer VSX-516
1088 Views 1 Reply 2 Participants Last post by  jkinan100
I'm having a problem getting Dolby Digital sound from my DVD player. I have the Samsung hooked to the Pioneer via digital coaxial cable. When playing a movie, the digital label shows up on my AVR. However, the signal is only digital, not Dolby Digital which is a separate label. I've checked the DVD disc menu to make sure it is DD 5.1 mode. The AVR is on the DVD/LD input source. I have a DVD 5.1 input source, but when I switch to it I get no sound. Any ideas on what I'm doing wrong here?
1 - 2 of 2 Posts
Not sure if you've solved this. To get Dolby Digital over Coax the output must be set from PCM to Bitstream in the Audio Setup menu.
Digital Out
- PCM : Converts to PCM(2CH) audio.
- Bitstream : Outputs Dolby Digital via digital output.
Select Bitstream when connecting to a Dolby Digital Decoder.
Enjoy,
John
See less See more
1 - 2 of 2 Posts
