Hello,
I own a Sony A1 OLED alongside an Oppo 203 Ultra Bluray Player.
Recently I tested Ultra HD Blurays in HDR such as the Harry Potter or the old Spiderman movies. A lot of scenes were showing extreme noise and I was thinking that the 4K upscale of an old movie was the culprit for this.
But I started to test some settings on my Oppo and when I turned off HDR or set it to "Strip Metadata", the picture became much cleaner ... the noise was still visible to a certain extend, but not nearly as aggressive as before. The overall brightness is not lower since I kept [X-Tended Dynamic Range] enabled which gives an HDR-like look but without the noise that is appearing when HDR is actually enabled.
I also watched some newer movies as well for comparison, for example Prometheus. The movie already has a quite clean look with only a tiny amount of noise but again in certain scenes of the movie, the already faint noise is completely gone when I turn off HDR or strip the metadata via the Oppo's settings.
Can anyone attest to that or perhaps even explain why that is?
EDIT:
As of now, it is hard to tell which component is actually causing this behavior so I have made a list and gathered some thoughts for troubleshooting:
Factors I assume relevant for the noise in HDR content:
1. AV Receiver Denon AVD 4300
2. HDMI Cable
3. Ultra Bluray Player Oppo 203
4. Sony A1 OLED TV settings (for Example X-tended Dynamic Range)
5. Sony A1 OLED TV itself
6. HDR issue
And here are my thoughts on narrowing down the issue for each factor and possibly troubleshoot:
1. Bypass AV Receiver by connecting the player directly to TV and test a 4K HDR scene that has a lot of noise
TESTED: connected the Oppo 203 directly to the TV but it did not change the outcome, when displaying HDR content the noise was visible when HDR was active and was reduced when stripping the metadata
2. Use a different HDMI cable to connect the BD player to the TV and test a 4K HDR scene that has a lot of noise
TESTED: also when the Oppo was directly connected to the TV with a different HDMI Cable (on a different HDMI Port) the outcome was still the same: lots of noise when HDR active, reduced when stripping metadata
3. Connect the PC directly to the TV and test a 4K HDR scene that has a lot of noise
TESTED: tested the same content via a PC and PowerDVD 17 Ultra. Also, when the same same HDR content was displayed, the outcome was still the same: when HDR was active, the noise was very pronounced. Unfortunately I wasn't able to strip the metadata so I deactivated the HDR on the TV itself... I doubt this has the same effect so I won't even go there.
4. Test a 4k HDR scene with a lot of noise and change the TVs settings for X-Tendeded Dynamic Range and Contrast
TESTED: When changing the settings of the TV like X-Tendeded Dynamic Range and Contrast, there is no change in terms of noise. The picture will get brighter or darker, but only stripping the metadata will really make a difference for HDR content. Interestingly, Noise reduction will not reduce the HDR noise.
5. Test HDR on a different TV (LG OLED) - see if it also makes a difference when HDR is activated or deactivated
TESTED: Thanks to Nobbygon who owns an LG HDR OLED TV and also an Oppo 203, he was testing HDR movies with HDR set to On and to Strip Metadata and was able to compare the settings. He confirmed that HDR while on will look very noisy/grainy and when stripping metadata, the noise is reduced (about 50%).
6. search the internet for clues, if HDR itself can cause this behavior:
As soon as I get to test and verify my above described findings, I will update my post
Best
Gregor
