1 - 8 of 8 Posts
Discussion Starter #1
Looking for a cheaper alternative then the Oppo to play media files (full BR rips) that can handle Dolby Atmos (bitstreaming), DTS:X (bitsteam), Dolby Vision and HDR10
Are there any out there ?
Shield
Shield itself doesn't care any of that. It is the software you use that needs the support of such. So, what you ask is up to the software of your choice. For example, for DV of BD rips, some software plays, some don't, mostly because the DV in MKV format is too new for most software to catch up the support. But ppl have being convert them into either ts or mp4 and play DV just fine in various players.
No, you are way out of loop/out of date on information. MakeMKV is now on version 1.5.3. A lot has changed.
Check out Zappit
1 - 8 of 8 Posts
