I'm at the point of ordering doors in my build. I've done some research and want to make sure I am on the right path. I have:
I've read that in a basement theater many have had success with a 1 3/4" Masonite solid core door w/proper seals (DIY or Zero type) and auto bottom.
That is my current plan - a 1 3/4" solid core interior door hung on a custom jamb to match the 15" depth. I was going to hit the easy button and pay for the Zero type seals and auto close bottom.
I originally thought I would need to build a bank vault style door (extra mass and double seals) with two independent jambs that didn't mechanically connect. That sounds like it might be overkill.
My GC is ordering the doors so I want to make sure I give him the correct info to avoid any issues/delays.
Questions
Any help is greatly appreciated!
- Double wall construction w/5.5" gap for a total of 15" jamb depth
- Three layers of drywall in theater w/GG, one layer outside
- Single door 36"x80", might do communicating if a single doesn't cut it
Questions
- How important is it to get a full 1 3/4" flush door vs the same depth solid core but with "decorative panels" to match the rest of the house (standard six panel)?
- I can't find a door slab that matches those specs on the big box sites. Are they only available as a "custom" order if you go to the desk?
- Also, how do I know I'm getting the right Masonite core density? Is it material type or weight that I should be looking for?
