I have the new Zoom Player 3.0 Pro and use it to play DVDs in widescreen mode thru my HTPC to my CRT PJ. In full screen mode, I sometimes (not always) have a bright dot showing on the lower left of the projected image (red, green, AND blue tubes). If I go back to normal desktop mode, the location of the dot corresponds to the very lower left corner pixel(s) of the Windows desktop (I can also see it on my computer monitor before I send the signal to the CRT PJ.) Resolution is 720x480 at 60 Hz, using PowerStrip and Geforce2 MX400. Sony 1031Q projector.
I see it when using ZP with WINDVD 4 Platinum filters, BUT I DON'T see it when I'm using WinDVD 4 Platinum as the actual player. Blanking Navigator controls for ZP don't make a difference (cropped the 2.35:1 image down to its borders on all sides).
The same thing also happened with the previous version of ZP.
I haven't found the common denominator. Sometimes I can simply exit ZP and reload and it's not there. Other times nothing will get rid of it when using ZP.
Any ideas? I don't want this to burn into my tubes.
Dan
Dan
