1 - 5 of 5 Posts
Hi to all, thanks to the hornresp experts (lilmike, soho54 etc) there is now a half-finished horn waiting in the workshop.
Presently, this is a 580 liters enclosure for a TH or OD. Now I am undecided if I should rather build one 580 l / 380 cm horn or a double horn with 2 x 290 liters / 380 cm.
I have compared the single and double horns, and surprisingly, the SPL is not very different between the two. putting 2 drivers in the same large horn doesnt improve the response, apparently. I have also simed one or two OD horns with the same lenght and volume ( and huge Vrc = living-room), but the SPL is lower and the phase response is much worse. I would use the 2 15NDL76 free to air and as offset driver on each side, has this trick been tried and if not, why ? So the internal dimensions of 41 x 75 x 190 cm are fixed ( for the prototype) and I would build 2 of them of course ! The setup will be combined with a sealed speaker from 150 Hz upwards. Thanks for your advice -- Marc
Since the files dont upload, I paste them ( they are for the double horn).
ID=39.00
Ang=1.0 x Pi
Eg=2
Rg=8.00
Fta=1.10
S1=400.00
S2=500.00
Par=60.00
F12=0.00
S2=500.00
S3=1200.00
Par=260.00
F23=0.00
S3=1200.00
S4=1350.00
Par=60.00
F34=0.00
S4=0.00
S5=0.00
L45=0.00
F45=0.00
Sd=855.00
Bl=22.50
Cms=1.87E-04
Rms=5.11
Mmd=84.57
Le=1.50
Re=5.30
TH=1
Vrc=0.00
Lrc=300.00
Ap=0.00
Lpt=0.00
Vtc=0.00
Atc=0.00
Pmax=100
Xmax=8.0
Path=0.0
Fr1=0.00
Fr2=0.00
Fr3=0.00
Fr4=0.00
Tal1=100
Tal2=100
Tal3=100
Tal4=100
Comment=TH.15NDL76
ID=39.00
Ang=1.0 x Pi
Eg=2.00
Rg=8.00
Fta=1.31
S1=400.00
S2=400.00
Par=30.00
F12=0.00
S2=400.00
S3=400.00
Par=30.00
F23=0.00
S3=400.00
S4=1350.00
Par=320.00
F34=0.00
S4=0.00
S5=0.00
L45=0.00
F45=0.00
Sd=855.00
Bl=22.50
Cms=1.87E-04
Rms=5.11
Mmd=84.57
Le=1.50
Re=5.30
OD=1
Vrc=0.00
Lrc=0.00
Ap1=0.00
Lp=0.00
Vtc=0.00
Atc=0.00
Pmax=100
Xmax=8.0
Path=0.0
Fr1=0.00
Fr2=0.00
Fr3=0.00
Fr4=0.00
Tal1=100
Tal2=100
Tal3=100
Tal4=100
Comment=OD.15NDL76
two "half horns" located side-by-side should model (and perform) the same as one large horn with two drivers. placement flexibility favors two "half horns" of course.
Discussion Starter · #3 ·
Prototype with options
Thanks LTD02 for your quick reply. We are going to glue the enclosure for a double horn this week. I dont want to cut the boards and make 2 separate horns, but rather build two double horns.
Do you think that 2 single horns with a mouth of 1300 cm2 would be enough for a 9 x 10 m room ? I have two sealed push-pull subwoofers with 18" drivers to make a comparison before making the final installation.
The TH produces better results than an OD in hornresp - what is the argument for an OD then ? For aesthetical reasons I wanted to mount the drivers outside the box - it's really not sexy to watch. But since the 15NDL76 has no real bass extension, this would be pointless. Since it is a OSB prototype, I will play with the drivers ( 1 or 2 per side) and use some 15FW76 as an alternative. If I manage to use the measurement set correctly I might post some results. Thank you again ! Marc
depends what you are trying to do. the offset driver may give you a little more clean and extended top end. the tapped horn will give you a little more extension and output on the bottom end.
while much larger than what you posted, the smoother top end is relatively evident. (that's a 2pi space model btw)
1 - 5 of 5 Posts
