CM
CM
CM Input file: C:\Python35\UHF Vert_UniFL_14Bay_AWG10_NoRefl.nec
CM Sweep ranges:
CM R0 = (470, 12, 21) with target levels [8, 11]
CM SWR target: [[2.7, 2.7]]
CM Target function: (4*max_ml+16*max_gain_diff)/20
CM Autosegmentation: 13 per 0.319149
CM
CM Score 1.53486
CM
CM HiVHF+UHF Super-14-Bay Bowtie, All SAME, Common FL, NO Refl, 4nec2 by holl_ands, 29May2016
CM BowLength=vrbl, BowSpacing=vrbl, TineSep=vrbl (AWG10 Elements), Hop=1.0-in.
CM NO Reflector. FeedSep=vrbl (AWG10). Ready for Python Optimization, 5 VARIABLES.
CM PYTHONSEG(13), AGT=1.0, NO Errors, Ignore Sharp Angle Warnings.
CM
CMD--OPT -s(470,12,21) -t(8,11) --swr-target=2.7
CMD--OPT --target-function=(4*max_ml+16*max_gain_diff)/20
CMD--OPT --auto-segmentation=13 --char-impedance=300 --num-cores=12
CMD--EVAL --auto-segmentation=0 --char-impedance=300 --num-cores=12
CMD--EVAL -s(174,6,8) -s(470,12,29)
CE
' SOURCE Wire Radius, Adjusted for AGT=1.0: UHF=0.0174, HiVHF=0.0064
SY Rsrc=0.0174
' Radius (in inches) of BOWTIE elements:
SY Rbow=0.051
' Radius (in inches) of FEEDLINE wires
SY Rfeed=0.051
' Separation at Crossover
SY Hop=1
' Conductivity (Copper=3.0e7, Alum=2.0e7, StainlessSteel=1.67e7)
SY Cond=3e+07
' Distance between the centers of the two INNER bowties:
SY ZBowII=9.03569' 7, 40
' From center of INNER bowtie to center of OUTER bowtie:
SY ZBowOI=ZBowII
' From center of OUTER bowtie to center of EXTERIOR bowtie:
SY ZBowOE=ZBowII
' From center of EXTERIOR bowtie to center of WAYOUT bowtie:
SY ZBowEW=ZBowII
' From center of OUTER bowtie to center of BEYOND bowtie:
SY ZBowWB=ZBowII
' From center of EXTERIOR bowtie to center of DOZEN bowtie:
SY ZBowBD=ZBowII
' From center of EXTERIOR bowtie to center of MAXED bowtie:
SY ZBowDM=ZBowII
' INNER Bow Whisker Length (lose some in bend):
SY BowLeni=8.495842' 7, 40
' OUTER Bow Whisker Length (lose some in bend):
SY BowLeno=BowLeni
' EXTERIOR Bow Whisker Length (lose some in bend):
SY BowLenE=BowLeni
' WAYOUT Bow Whisker Length (lose some in bend):
SY BowLenW=BowLeni
' BEYOND Bow Whisker Length (lose some in bend):
SY BowLenB=BowLeni
' DOZEN Bow Whisker Length (lose some in bend):
SY BowLenD=BowLeni
' MAXED Bow Whisker Length (lose some in bend):
SY BowLenM=BowLeni
' INNER Bow Forward Sweep distance at tip of the whisker:
SY BowSwpi=0
' OUTER Bow Forward Sweep distance at tip of the whisker:
SY BowSwpo=0
' EXTERIOR Bow Forward Sweep distance at tip of the whisker:
SY BowSwpE=0
' WAYOUT Bow Forward Sweep distance at tip of the whisker:
SY BowSwpW=0
' BEYOND Bow Forward Sweep distance at tip of the whisker:
SY BowSwpB=0
' DOZEN Bow Forward Sweep distance at tip of the whisker:
SY BowSwpD=0
' MAXED Bow Forward Sweep distance at tip of the whisker:
SY BowSwpM=0
' INNER Bow Tine Separation:
SY TineSepi=6.233444' 2, 10
' OUTER Bow Tine Separation:
SY TineSepo=TineSepi
' EXTERIOR Bow Tine Separation:
SY TineSepE=TineSepi
' WAYOUT Bow Tine Separation:
SY TineSepW=TineSepi
' BEYOND Bow Tine Separation:
SY TineSepB=TineSepi
' DOZEN Bow Tine Separation:
SY TineSepD=TineSepi
' MAXED Bow Tine Separation:
SY TineSepM=TineSepi
' Separation between two FEEDLINE wires: [CONSTRAINT: TRY ALL THE SAME.]
SY FeedSep=3.45969' 0.75, 6
' From center of Feedline Cross-Over to center of OUTER Bowtie:
SY ZCross=2.845246' 1.25, 6
' From center of Feedline Cross-Over to center of EXTERIOR Bowtie:
SY ZCrossE=ZCross
' From center of Feedline Cross-Over to center of WAYOUT Bowtie:
SY ZCrossW=ZCross
' From center of Feedline Cross-Over to center of BEYOND Bowtie:
SY ZCrossB=ZCross
' From center of Feedline Cross-Over to center of DOZEN Bowtie:
SY ZCrossD=ZCross
' From center of Feedline Cross-Over to center of MAXED Bowtie:
SY ZCrossM=ZCross
' Bowtie Separation in FRONT of Reflector (which is at X=0): [NOT USED HERE]
SY RS=0
' Calculated from above INPUT Values:
SY ZBowInr=ZBowII/2' Distance from antenna center to center of INNER bowtie
SY ZBowOut=ZBowII/2+ZBowOI' Distance from antenna center to center of OUTER bowtie
SY ZBowExt=ZBowII/2+ZBowOI+ZBowOE' From antenna center to center of EXTERIOR bowtie
SY ZBowWay=ZBowII/2+ZBowOI+ZBowOE+ZBowEW' From antenna center to center of WAYOUT bowtie
SY ZBowBey=ZBowII/2+ZBowOI+ZBowOE+ZBowEW+ZBowWB' From antenna center to BEYOND bowtie
SY ZBowMax=ZBowII/2+ZBowOI+ZBowOE+ZBowEW+ZBowWB+ZBowBD' Aantenna center to DOZEN bowtie
SY ZBowDoz=ZBowII/2+ZBowOI+ZBowOE+ZBowEW+ZBowWB+ZBowBD+ZBowDM' Antenna center to MAXED bowtie
SY Z1=ZBowOut+TineSepo/2
SY Z2=ZBowOut
SY Z3=ZBowOut-TineSepo/2
SY Z4=ZBowOut-ZCross+0.875
SY Z5=ZBowOut-ZCross
SY Z6=ZBowOut-ZCross-0.875
SY Z7=ZBowInr+TineSepi/2
SY Z8=ZBowInr
SY Z9=ZBowInr-TineSepi/2
SY Z11=ZBowExt+TineSepE/2
SY Z12=ZBowExt
SY Z13=ZBowExt+-TineSepE/2
SY Z14=ZBowExt-ZCrossE+0.875
SY Z15=ZBowExt-ZCrossE
SY Z16=ZBowExt-ZCrossE-0.875
SY Z21=ZBowWay+TineSepW/2
SY Z22=ZBowWay
SY Z23=ZBowWay+-TineSepW/2
SY Z24=ZBowWay-ZCrossW+0.875
SY Z25=ZBowWay-ZCrossW
SY Z26=ZBowWay-ZCrossW-0.875
SY Z31=ZBowBey+TineSepB/2
SY Z32=ZBowBey
SY Z33=ZBowBey+-TineSepB/2
SY Z34=ZBowBey-ZCrossB+0.875
SY Z35=ZBowBey-ZCrossB
SY Z36=ZBowBey-ZCrossB-0.875
SY Z41=ZBowDoz+TineSepD/2
SY Z42=ZBowDoz
SY Z43=ZBowDoz+-TineSepD/2
SY Z44=ZBowDoz-ZCrossD+0.875
SY Z45=ZBowDoz-ZCrossD
SY Z46=ZBowDoz-ZCrossD-0.875
SY Z51=ZBowMax+TineSepM/2
SY Z52=ZBowMax
SY Z53=ZBowMax+-TineSepM/2
SY Z54=ZBowMax-ZCrossM+0.875
SY Z55=ZBowMax-ZCrossM
SY Z56=ZBowMax-ZCrossM-0.875
SY YBowInr=FeedSep/2+(BowLeni^2-(TineSepi/2)^2-BowSwpi^2)^0.5' Ymax for INNER Bowties
SY YBowOut=FeedSep/2+(BowLeno^2-(TineSepo/2)^2-BowSwpo^2)^0.5' Ymax for OUTER Bowties
SY YBowExt=FeedSep/2+(BowLenE^2-(TineSepE/2)^2-BowSwpE^2)^0.5' Ymax for EXTERIOR Bowties
SY YBowWay=FeedSep/2+(BowLenW^2-(TineSepW/2)^2-BowSwpW^2)^0.5' Ymax for WAYOUT Bowties
SY YBowBey=FeedSep/2+(BowLenB^2-(TineSepB/2)^2-BowSwpB^2)^0.5' Ymax for BEYOND Bowties
SY YBowDoz=FeedSep/2+(BowLenD^2-(TineSepD/2)^2-BowSwpD^2)^0.5' Ymax for DOZEN Bowties
SY YBowMax=FeedSep/2+(BowLenM^2-(TineSepM/2)^2-BowSwpM^2)^0.5' Ymax for MAXED Bowties
' # segs X1 Y1 Z1 X2 Y2 Z2 radius
' SIMULATED SOURCE WIRE:
GW 1 3 RS -FeedSep/2 0.0 RS FeedSep/2 0.0 Rsrc
' INNER BOWTIES:
GW 2 9 BowSwpi+RS YBowInr Z7 RS FeedSep/2 Z8 Rbow
GW 3 9 BowSwpi+RS YBowInr Z9 RS FeedSep/2 Z8 Rbow
GW 4 9 RS -FeedSep/2 Z8 BowSwpi+RS -YBowInr Z7 Rbow
GW 5 9 RS -FeedSep/2 Z8 BowSwpi+RS -YBowInr Z9 Rbow
GW 6 9 BowSwpi+RS YBowInr -Z7 RS FeedSep/2 -Z8 Rbow
GW 7 9 BowSwpi+RS YBowInr -Z9 RS FeedSep/2 -Z8 Rbow
GW 8 9 RS -FeedSep/2 -Z8 BowSwpi+RS -YBowInr -Z7 Rbow
GW 9 9 RS -FeedSep/2 -Z8 BowSwpi+RS -YBowInr -Z9 Rbow
' OUTER BOWTIES:
GW 10 9 BowSwpo+RS YBowOut Z1 RS FeedSep/2 Z2 Rbow
GW 11 9 BowSwpo+RS YBowOut Z3 RS FeedSep/2 Z2 Rbow
GW 12 9 RS -FeedSep/2 Z2 BowSwpo+RS -YBowOut Z1 Rbow
GW 13 9 RS -FeedSep/2 Z2 BowSwpo+RS -YBowOut Z3 Rbow
GW 14 9 BowSwpo+RS YBowOut -Z1 RS FeedSep/2 -Z2 Rbow
GW 15 9 BowSwpo+RS YBowOut -Z3 RS FeedSep/2 -Z2 Rbow
GW 16 9 RS -FeedSep/2 -Z2 BowSwpo+RS -YBowOut -Z1 Rbow
GW 17 9 RS -FeedSep/2 -Z2 BowSwpo+RS -YBowOut -Z3 Rbow
' EXTERIOR BOWTIES:
GW 40 9 BowSwpE+RS YBowExt Z11 RS FeedSep/2 Z12 Rbow
GW 41 9 BowSwpE+RS YBowExt Z13 RS FeedSep/2 Z12 Rbow
GW 42 9 RS -FeedSep/2 Z12 BowSwpE+RS -YBowExt Z11 Rbow
GW 43 9 RS -FeedSep/2 Z12 BowSwpE+RS -YBowExt Z13 Rbow
GW 44 9 BowSwpE+RS YBowExt -Z11 RS FeedSep/2 -Z12 Rbow
GW 45 9 BowSwpE+RS YBowExt -Z13 RS FeedSep/2 -Z12 Rbow
GW 46 9 RS -FeedSep/2 -Z12 BowSwpE+RS -YBowExt -Z11 Rbow
GW 47 9 RS -FeedSep/2 -Z12 BowSwpE+RS -YBowExt -Z13 Rbow
' WAYOUT BOWTIES:
GW 70 9 BowSwpW+RS YBowWay Z21 RS FeedSep/2 Z22 Rbow
GW 71 9 BowSwpW+RS YBowWay Z23 RS FeedSep/2 Z22 Rbow
GW 72 9 RS -FeedSep/2 Z22 BowSwpW+RS -YBowWay Z21 Rbow
GW 73 9 RS -FeedSep/2 Z22 BowSwpW+RS -YBowWay Z23 Rbow
GW 74 9 BowSwpW+RS YBowWay -Z21 RS FeedSep/2 -Z22 Rbow
GW 75 9 BowSwpW+RS YBowWay -Z23 RS FeedSep/2 -Z22 Rbow
GW 76 9 RS -FeedSep/2 -Z22 BowSwpW+RS -YBowWay -Z21 Rbow
GW 77 9 RS -FeedSep/2 -Z22 BowSwpW+RS -YBowWay -Z23 Rbow
' BEYOND BOWTIES:
GW 110 9 BowSwpB+RS YBowBey Z31 RS FeedSep/2 Z32 Rbow
GW 111 9 BowSwpB+RS YBowBey Z33 RS FeedSep/2 Z32 Rbow
GW 112 9 RS -FeedSep/2 Z32 BowSwpB+RS -YBowBey Z31 Rbow
GW 113 9 RS -FeedSep/2 Z32 BowSwpB+RS -YBowBey Z33 Rbow
GW 114 9 BowSwpB+RS YBowBey -Z31 RS FeedSep/2 -Z32 Rbow
GW 115 9 BowSwpB+RS YBowBey -Z33 RS FeedSep/2 -Z32 Rbow
GW 116 9 RS -FeedSep/2 -Z32 BowSwpB+RS -YBowBey -Z31 Rbow
GW 117 9 RS -FeedSep/2 -Z32 BowSwpB+RS -YBowBey -Z33 Rbow
' DOZEN BOWTIES:
GW 140 9 BowSwpD+RS YBowDoz Z41 RS FeedSep/2 Z42 Rbow
GW 141 9 BowSwpD+RS YBowDoz Z43 RS FeedSep/2 Z42 Rbow
GW 142 9 RS -FeedSep/2 Z42 BowSwpD+RS -YBowDoz Z41 Rbow
GW 143 9 RS -FeedSep/2 Z42 BowSwpD+RS -YBowDoz Z43 Rbow
GW 144 9 BowSwpD+RS YBowDoz -Z41 RS FeedSep/2 -Z42 Rbow
GW 145 9 BowSwpD+RS YBowDoz -Z43 RS FeedSep/2 -Z42 Rbow
GW 146 9 RS -FeedSep/2 -Z42 BowSwpD+RS -YBowDoz -Z41 Rbow
GW 147 9 RS -FeedSep/2 -Z42 BowSwpD+RS -YBowDoz -Z43 Rbow
' MAXED BOWTIES:
GW 170 9 BowSwpM+RS YBowMax Z51 RS FeedSep/2 Z52 Rbow
GW 171 9 BowSwpM+RS YBowMax Z53 RS FeedSep/2 Z52 Rbow
GW 172 9 RS -FeedSep/2 Z52 BowSwpM+RS -YBowMax Z51 Rbow
GW 173 9 RS -FeedSep/2 Z52 BowSwpM+RS -YBowMax Z53 Rbow
GW 174 9 BowSwpM+RS YBowMax -Z51 RS FeedSep/2 -Z52 Rbow
GW 175 9 BowSwpM+RS YBowMax -Z53 RS FeedSep/2 -Z52 Rbow
GW 176 9 RS -FeedSep/2 -Z52 BowSwpM+RS -YBowMax -Z51 Rbow
GW 177 9 RS -FeedSep/2 -Z52 BowSwpM+RS -YBowMax -Z53 Rbow
' OUTER CROSS-OVER FEEDLINES:
GW 18 2 RS FeedSep/2 Z2 RS FeedSep/2 Z4 Rfeed
GW 19 2 RS -FeedSep/2 Z2 RS -FeedSep/2 Z4 Rfeed
GW 20 5 RS FeedSep/2 Z6 RS FeedSep/2 Z8 Rfeed
GW 21 5 RS -FeedSep/2 Z6 RS -FeedSep/2 Z8 Rfeed
GW 22 2 RS -FeedSep/2 Z6 Hop/2+RS 0.0 Z5 Rfeed
GW 23 2 RS FeedSep/2 Z4 Hop/2+RS 0.0 Z5 Rfeed
GW 24 2 RS FeedSep/2 Z6 -Hop/2+RS 0.0 Z5 Rfeed
GW 25 2 RS -FeedSep/2 Z4 -Hop/2+RS 0.0 Z5 Rfeed
GW 26 2 RS FeedSep/2 -Z2 RS FeedSep/2 -Z4 Rfeed
GW 27 2 RS -FeedSep/2 -Z2 RS -FeedSep/2 -Z4 Rfeed
GW 28 5 RS FeedSep/2 -Z6 RS FeedSep/2 -Z8 Rfeed
GW 29 5 RS -FeedSep/2 -Z6 RS -FeedSep/2 -Z8 Rfeed
GW 30 2 RS -FeedSep/2 -Z6 Hop/2+RS 0.0 -Z5 Rfeed
GW 31 2 RS FeedSep/2 -Z4 Hop/2+RS 0.0 -Z5 Rfeed
GW 32 2 RS FeedSep/2 -Z6 -Hop/2+RS 0.0 -Z5 Rfeed
GW 33 2 RS -FeedSep/2 -Z4 -Hop/2+RS 0.0 -Z5 Rfeed
' EXTERIOR CROSS-OVER FEEDLINES:
GW 48 2 RS FeedSep/2 Z12 RS FeedSep/2 Z14 Rfeed
GW 49 2 RS -FeedSep/2 Z12 RS -FeedSep/2 Z14 Rfeed
GW 50 5 RS FeedSep/2 Z16 RS FeedSep/2 Z2 Rfeed
GW 51 5 RS -FeedSep/2 Z16 RS -FeedSep/2 Z2 Rfeed
GW 52 2 RS -FeedSep/2 Z16 Hop/2+RS 0.0 Z15 Rfeed
GW 53 2 RS FeedSep/2 Z14 Hop/2+RS 0.0 Z15 Rfeed
GW 54 2 RS FeedSep/2 Z16 -Hop/2+RS 0.0 Z15 Rfeed
GW 55 2 RS -FeedSep/2 Z14 -Hop/2+RS 0.0 Z15 Rfeed
GW 56 2 RS FeedSep/2 -Z12 RS FeedSep/2 -Z14 Rfeed
GW 57 2 RS -FeedSep/2 -Z12 RS -FeedSep/2 -Z14 Rfeed
GW 58 5 RS FeedSep/2 -Z16 RS FeedSep/2 -Z2 Rfeed
GW 59 5 RS -FeedSep/2 -Z16 RS -FeedSep/2 -Z2 Rfeed
GW 60 2 RS -FeedSep/2 -Z16 Hop/2+RS 0.0 -Z15 Rfeed
GW 61 2 RS FeedSep/2 -Z14 Hop/2+RS 0.0 -Z15 Rfeed
GW 62 2 RS FeedSep/2 -Z16 -Hop/2+RS 0.0 -Z15 Rfeed
GW 63 2 RS -FeedSep/2 -Z14 -Hop/2+RS 0.0 -Z15 Rfeed
' WAYOUT CROSS-OVER FEEDLINES:
GW 88 2 RS FeedSep/2 Z22 RS FeedSep/2 Z24 Rfeed
GW 89 2 RS -FeedSep/2 Z22 RS -FeedSep/2 Z24 Rfeed
GW 90 5 RS FeedSep/2 Z26 RS FeedSep/2 Z12 Rfeed
GW 91 5 RS -FeedSep/2 Z26 RS -FeedSep/2 Z12 Rfeed
GW 92 2 RS -FeedSep/2 Z26 Hop/2+RS 0.0 Z25 Rfeed
GW 93 2 RS FeedSep/2 Z24 Hop/2+RS 0.0 Z25 Rfeed
GW 94 2 RS FeedSep/2 Z26 -Hop/2+RS 0.0 Z25 Rfeed
GW 95 2 RS -FeedSep/2 Z24 -Hop/2+RS 0.0 Z25 Rfeed
GW 96 2 RS FeedSep/2 -Z22 RS FeedSep/2 -Z24 Rfeed
GW 97 2 RS -FeedSep/2 -Z22 RS -FeedSep/2 -Z24 Rfeed
GW 98 5 RS FeedSep/2 -Z26 RS FeedSep/2 -Z12 Rfeed
GW 99 5 RS -FeedSep/2 -Z26 RS -FeedSep/2 -Z12 Rfeed
GW 100 2 RS -FeedSep/2 -Z26 Hop/2+RS 0.0 -Z25 Rfeed
GW 101 2 RS FeedSep/2 -Z24 Hop/2+RS 0.0 -Z25 Rfeed
GW 102 2 RS FeedSep/2 -Z26 -Hop/2+RS 0.0 -Z25 Rfeed
GW 103 2 RS -FeedSep/2 -Z24 -Hop/2+RS 0.0 -Z25 Rfeed
' BEYOND CROSS-OVER FEEDLINES:
GW 118 2 RS FeedSep/2 Z32 RS FeedSep/2 Z34 Rfeed
GW 119 2 RS -FeedSep/2 Z32 RS -FeedSep/2 Z34 Rfeed
GW 120 5 RS FeedSep/2 Z36 RS FeedSep/2 Z22 Rfeed
GW 121 5 RS -FeedSep/2 Z36 RS -FeedSep/2 Z22 Rfeed
GW 122 2 RS -FeedSep/2 Z36 Hop/2+RS 0.0 Z35 Rfeed
GW 123 2 RS FeedSep/2 Z34 Hop/2+RS 0.0 Z35 Rfeed
GW 124 2 RS FeedSep/2 Z36 -Hop/2+RS 0.0 Z35 Rfeed
GW 125 2 RS -FeedSep/2 Z34 -Hop/2+RS 0.0 Z35 Rfeed
GW 126 2 RS FeedSep/2 -Z32 RS FeedSep/2 -Z34 Rfeed
GW 127 2 RS -FeedSep/2 -Z32 RS -FeedSep/2 -Z34 Rfeed
GW 128 5 RS FeedSep/2 -Z36 RS FeedSep/2 -Z22 Rfeed
GW 129 5 RS -FeedSep/2 -Z36 RS -FeedSep/2 -Z22 Rfeed
GW 130 2 RS -FeedSep/2 -Z36 Hop/2+RS 0.0 -Z35 Rfeed
GW 131 2 RS FeedSep/2 -Z34 Hop/2+RS 0.0 -Z35 Rfeed
GW 132 2 RS FeedSep/2 -Z36 -Hop/2+RS 0.0 -Z35 Rfeed
GW 133 2 RS -FeedSep/2 -Z34 -Hop/2+RS 0.0 -Z35 Rfeed
' DOZEN CROSS-OVER FEEDLINES:
GW 148 2 RS FeedSep/2 Z42 RS FeedSep/2 Z44 Rfeed
GW 149 2 RS -FeedSep/2 Z42 RS -FeedSep/2 Z44 Rfeed
GW 150 5 RS FeedSep/2 Z46 RS FeedSep/2 Z52 Rfeed
GW 151 5 RS -FeedSep/2 Z46 RS -FeedSep/2 Z52 Rfeed
GW 152 2 RS -FeedSep/2 Z46 Hop/2+RS 0.0 Z45 Rfeed
GW 153 2 RS FeedSep/2 Z44 Hop/2+RS 0.0 Z45 Rfeed
GW 154 2 RS FeedSep/2 Z46 -Hop/2+RS 0.0 Z45 Rfeed
GW 155 2 RS -FeedSep/2 Z44 -Hop/2+RS 0.0 Z45 Rfeed
GW 156 2 RS FeedSep/2 -Z42 RS FeedSep/2 -Z44 Rfeed
GW 157 2 RS -FeedSep/2 -Z42 RS -FeedSep/2 -Z44 Rfeed
GW 158 5 RS FeedSep/2 -Z46 RS FeedSep/2 -Z52 Rfeed
GW 159 5 RS -FeedSep/2 -Z46 RS -FeedSep/2 -Z52 Rfeed
GW 160 2 RS -FeedSep/2 -Z46 Hop/2+RS 0.0 -Z45 Rfeed
GW 161 2 RS FeedSep/2 -Z44 Hop/2+RS 0.0 -Z45 Rfeed
GW 162 2 RS FeedSep/2 -Z46 -Hop/2+RS 0.0 -Z45 Rfeed
GW 163 2 RS -FeedSep/2 -Z44 -Hop/2+RS 0.0 -Z45 Rfeed
' MAXED CROSS-OVER FEEDLINES:
GW 188 2 RS FeedSep/2 Z52 RS FeedSep/2 Z54 Rfeed
GW 189 2 RS -FeedSep/2 Z52 RS -FeedSep/2 Z54 Rfeed
GW 190 5 RS FeedSep/2 Z56 RS FeedSep/2 Z32 Rfeed
GW 191 5 RS -FeedSep/2 Z56 RS -FeedSep/2 Z32 Rfeed
GW 192 2 RS -FeedSep/2 Z56 Hop/2+RS 0.0 Z55 Rfeed
GW 193 2 RS FeedSep/2 Z54 Hop/2+RS 0.0 Z55 Rfeed
GW 194 2 RS FeedSep/2 Z56 -Hop/2+RS 0.0 Z55 Rfeed
GW 195 2 RS -FeedSep/2 Z54 -Hop/2+RS 0.0 Z55 Rfeed
GW 196 2 RS FeedSep/2 -Z52 RS FeedSep/2 -Z54 Rfeed
GW 197 2 RS -FeedSep/2 -Z52 RS -FeedSep/2 -Z54 Rfeed
GW 198 5 RS FeedSep/2 -Z56 RS FeedSep/2 -Z32 Rfeed
GW 199 5 RS -FeedSep/2 -Z56 RS -FeedSep/2 -Z32 Rfeed
GW 200 2 RS -FeedSep/2 -Z56 Hop/2+RS 0.0 -Z55 Rfeed
GW 201 2 RS FeedSep/2 -Z54 Hop/2+RS 0.0 -Z55 Rfeed
GW 202 2 RS FeedSep/2 -Z56 -Hop/2+RS 0.0 -Z55 Rfeed
GW 203 2 RS -FeedSep/2 -Z54 -Hop/2+RS 0.0 -Z55 Rfeed
' INNER FEEDLINES:
GW 34 5 RS FeedSep/2 Z8 RS FeedSep/2 0.0 Rfeed
GW 35 5 RS -FeedSep/2 Z8 RS -FeedSep/2 0.0 Rfeed
GW 36 5 RS FeedSep/2 -Z8 RS FeedSep/2 0.0 Rfeed
GW 37 5 RS -FeedSep/2 -Z8 RS -FeedSep/2 0.0 Rfeed
GS 0 0 0.0254' CONVERT ABOVE FROM INCHES TO METERS FOR NEC.
GE 0' No Ground Plane
GN -1' Free Space
EK 0' Enable Extended Kernel
LD 5 0 0 0 Cond 0' Conductivity
EX 0 1 2 0 1 0
' FR Freq Sweep choices in order of increasing calculation time (fm holl_ands):
' FR 0 0 0 0 470 0 ' Fixed Frequency
FR 0 29 0 0 470 12 ' Freq Sweep 470-806 every 12 MHz - OLD UHF BAND
' FR 0 39 0 0 470 6 ' Freq Sweep 470-698 every 6 MHz - PREFERRED FOR UHF
' FR 0 77 0 0 470 3 ' Freq Sweep 470-698 every 3 MHz
' FR 0 153 0 0 470 1.5 ' Freq Sweep 470-698 every 1.5 MHz
' FR 0 71 0 0 300 10 ' Freq Sweep 300-1000 every 10 MHz - WIDEBAND SWEEP
' FR Hi-VHF choices:
' FR 0 15 0 0 174 3 ' Freq Sweep 174-216 every 3 MHz
' FR 0 29 0 0 174 1.5 ' Freq Sweep 174-216 every 1.5 MHz - PREFERRED
' FR 0 43 0 0 174 1 ' Freq Sweep 174-216 every 1 MHz - Hi-Rez
' FR 0 26 0 0 150 6 ' Freq Sweep 150-300 every 6 MHz - WIDEBAND SWEEP
' FR Lo-VHF choices:
' FR 0 19 0 0 54 3 ' Frequency Sweep every 3 MHz for Ch2-6 + FM
' FR 0 35 0 0 54 1 ' Frequency Sweep every 1 MHz for Ch2-6
' FR 0 36 0 0 75 1 ' Frequency Sweep every 1 MHz for Ch5 + Ch6 + FM
' RP choices in order of increasing calculation time:
' RP 0 1 1 1510 90 0 1 1 0 0 ' 1D Gain toward 90-deg Azimuth
' RP 0 1 37 1510 90 0 1 5 0 0 ' 2D (Left only) Azimuthal Gain Slice
RP 0 1 73 1510 90 0 1 5 0 0 ' 2D Azimuthal Gain Slice - PREFERRED
' RP 0 73 1 1510 90 0 5 1 0 0 ' 2D Elevation Gain Slice
' RP 0 73 73 1510 90 0 5 5 0 0 ' 3D Lower Hemisphere reveals antenna
' RP 0 285 73 1510 90 0 5 5 0 0 ' 3D Full Coverage obscures antenna
EN
