I recently ordered the Jamo S606 set of speakers
For the receiver it's down to these two:
Yamaha-RX-V371BL
Power Output: 100W x 5 Banana-plug Compatible
Frequency Response: 10Hz - 100kHz +0,-3dB
Total Harmonic Distortion: 0.06%
Signal-to-Noise Ratio: 98dB
Standby Power Consumption (HDMI Off, Standby Through Off): 0.1W
Dimensions (WxHxD): 17-1/8" x 6" x 12-3/8"
Weight: 16.5 lbs
or
Onkyo-TX-NR509
Product Features
80 Watts per Channel at 8 Ohms, 20 Hz?20 kHz, 0.7%, 2 Channels Driven, FTC; 110 Watts per Channel at 6 Ohms, 1 kHz, 0.9%, 2 Channels Driven, FTC
4 HDMI Inputs and 1 Output, HDMI Support for 3D, Audio Return Channel, Deep Color, x.v.Color, LipSync, Dolby TrueHD, DTS-HD Master Audio, DVD-Audio
Direct Digital Connection of iPod/iPhone via Front-Panel USB Port
Network Capability
"Easy to Use" On?screen Display (OSD) via HDMI
The onkyo seems to have better reviews and more features. I don't care much for the network capability since I will be running audio/video through my apple tv running xbmc. I also don't care for the ipod connector although I may use it sparingly. The on-screen display is nice, but really how often do I need to use that
... so basically my main concern is sound quality. I want the best sound for those speakers. Which receiver would you get? Or do you recommend something other than these two?
Thanks in advance.
Yamaha-RX-V371BL
Weight: 16.5 lbs
or
Onkyo-TX-NR509
Product Features
Network Capability
Thanks in advance.
