Status
Not open for further replies.
1 - 6 of 6 Posts
· Registered
Hi, I'm running dscaler 4.16. I come across a strange phenomena. The brightness of the image seems to change by itself. The picture is suddenly dim. After a major scene change, the picture will become brighter and for a while, dim all of a sudden again. I tried different deinterlacing method and it won't help. Any comment? (I turned off the automatic deinterlancing)
I'm using Flyvideo2000 capture card.
· Registered
Sure sounds like a macrovison thing... Don't know if you could get around it by adjusting the macrovision timing (D and shift+D on keyboard) in dscaler or not, but it might be worth a try.
Good Luck,
David
1 - 6 of 6 Posts
Status
