Status
Not open for further replies.
1 - 7 of 7 Posts
Discussion Starter #1
Okay, I give up. What is going on here. Initially I thought it was a genlock problem, but now I have no idea what is going on:
Cyan bleedthrough:
http://www.neish.com/dscaler/cyan.jpg
Blue:
http://www.neish.com/dscaler/blue.jpg
Green:
http://www.neish.com/dscaler/green1.jpg
Another green:
http://www.neish.com/dscaler/green2.jpg
Cyan and green:
http://www.neish.com/dscaler/cyanAndGreen.jpg
Cyan, green and yellow(?):
http://www.neish.com/dscaler/cyanGreenYellow.jpg
Since more than one color is showing through at a time, it doesn't seem like a genlock color problem.
Also I have a magenta line across the bottom of my screen when running dScaler.
Configuration:
Athlon 800
Pinnacle PCTV
GeForce II GTS (Creative Labs brand)
dScaler
D-ILA, HTPC, HDTV, Panamorph(?)
[This message has been edited by JeremyNeish (edited 05-18-2001).]
Jeremy -
I have sometimes seen that kind of color blossoming when the BDELAY parm is too low.
Try hitting either D or sh-D a few times.
The band at the bottom can probably be corrected with Overlay in the Video Adjustments screen.
- Tom
Getting started:
HTPC Faq , dScaler , Xcel's Links .
Discussion Starter #3
Upon closer examination, it's almost like very high saturated (intense chroma) areas suddenly invert. I don't think adjusting the color levels helps. But I will double check as soon as I get home.
Hi !
Check your Desktop, is anything cyan behind the DScaler Window ?
DTV uses a "Magenta" Mask, so everything behind the DTC Window which was colored Magenta gets a "shine-trough".
Might be, that DScaler is switched to cyan ? http://www.avsforum.com/ubb/wink.gif
Richard
PS.: Littlew edit:
What i see is that these "shinetroughs" are all!! in Magenta Areas of the Sourcepic !!
So i think, you DO have Cyan behind the DScaler Window !
Close all other Windows in the background, also you might check a black desktop in the background, should solve the problem http://www.avsforum.com/ubb/smile.gif
[This message has been edited by Richard-*********.de (edited 05-18-2001).]
Discussion Starter #5
Tom,
Thanks! The D and sh-D solved the problem! However the magenta line at the bottom is still there. I looked for "Overlay" in the Video Adjustments screen, but there is no such setting. There is "Overscan" but that didn't help. Any ideas?
Thanks again,
Jeremy
Jeremy -
Yes, I should type more carefully. I did mean Overscan. Sorry it didn't help.
That pink line is vaguely familiar to me from the mailing list but I don't remember what it is about.
Maybe something to do with Aspect Ratio. Let's hope it's fixed in the new release as I know basically nothing about that code.
Please, any other DScaler folks jump in here.
- Tom
Getting started:
HTPC FAQ , dScaler , Xcel's Links .
Hi everybody.
Hopefully, the auto-detect on aspect ratio (which still marked as 'experimental') can be improved on the upcoming releases.
No, it will not be improved in comparison to the last alpha version. Maybe default values for ini parameters will be updated if you all give me your values (see specific thread).
what is the linear correction filter?
It is a new filter I created to apply trapezoidal correction. But it is more generic in fact. For the moment, it is unsable because it eats really too much CPU.
it's better on my application than the gamma filter.
With default ini parameters, this filter does nothing ! http://www.avsforum.com/ubb/smile.gif
Still marked as 'experimental', I hope the linear filter algorithm will be perfected in the next release.
Not in the upcoming release. But I hope for the next one.
Laurent
[This message has been edited by Laurent Garnier (edited 05-21-2001).]
1 - 7 of 7 Posts
Status
