Tons of capture cards around, fewer which are supported by Dscaler, fewer still which have a component input.
Svideo is okay, but component is better. Since it's all analog, the better I can have it, the less I'll worry about the inevitable degradation.
Dscaler compatibility is extremely important. Basically what I intend to do is capture NTSC video (from all sorts of sources: gaming consoles, VCR, DirecTV), deinterlace it with Dscaler, scale it with (heck if I know; still researching), and then output it with a Radeon (something) via its DVI-out. The reason I mention all of this is on the off-chance that somebody has a better solution (for example, maybe there is a capture card with component-in AND DVI-out).
I know about the IgniterRT. Not sure if it's Dscaler-compatible, but the price (thousands of dollars) makes it moot. I've found plenty of cards with everything I need _except_ component-in, for $400 or less.
This doesn't seem to be common knowledge. Does anyone know of a Dscaler-compatible capture card with component input, which will be able to function in a PC with a Radeon? Thanks in advance.
