Status
Not open for further replies.
1 - 5 of 5 Posts
I just downloaded Dscaler and I extracted all the files. When I click the .exe the start screen for Dscaler comes up and it goes through a big list of stuff (loading it I guess) then it stops at No suitable Harware.
I have Windows XP and my graphics card is an NVIDIA GeForce 2 MX/MX 400. Also I use Power DVD to play my DVDs with my computers DVD drive.
If you need anymore info let me know. Any help will be greatly appreciated.
Thanks!! :D
DScaler is designed to deinterlace and filter input coming from a capture card. Not sure what you are trying to use it for. This capture card should be one listed on the DScaler Site, I use the Pinnacle Rave TV Card, works great.
You need a Dscaler compatible video capture card. From the Dscaler web site F.A.Q.:
Which capture card can I use ?
Almost any card (and that means A LOT) based of former Brooktree (now Conexant) chips including bt848/878/879 will work for video only. Why those ? These chips are easy to program (there has been A LOT of software based on those) and are very cheap. This means many manufacturers have (and are still) produced cards based on those chips.
Sound from the tuner is not always supported and adding this for a lot of cards is not a developement priority.
While we can't (and won't) claim "this card is the one you need", here are a few that have been sucessfully used by some users.
Zoltrix Genie TV http://www.zoltrix-int.com/products/...8MMZXGENIE.htm
The WinTV series from Hauppage http://www.hauppage.com/html/products.htm
Guillemot maxi video 3 http://fr.guillemot.com/brand/gamme/...tvvidpci3.html
The Pinacle Studio PCTV http://www.pinnaclesys.com/ProductPage.asp?Product_ID=6
Take a look at the card list . This will never be complete so feel free to drop us an email reporting your experience with DScaler and your card. Also note that just because a card is on the list does not mean that it will work properly. Some features especially sound may not work correctly.
nope.. there is a way but it takes a couple modded cards that might still be available.. check out the thread on the x-capture card with the pdi mod
1 - 5 of 5 Posts
Status
