1 - 20 of 26 Posts
Hi everyone,
The task has been given to me to buy a camcorder for work. After a bit of talking, I convinced them to consider DSLRs as well.
It would be used for anything from interviews to snippets of fundraising dinners we'd have. Sound is very important here. They have expressed that they need to hear the interviewee, and not the room noise (which is a problem they've had before). One guy suggested a lapel mic (which we have: http://www.amazon.com/Rode-Smartlav-Lavalier-Microphone-Smartphones/product-reviews/B00BHN05H2/ref=dp_top_cm_cr_acr_txt?showViewpoints=1 ), and I suggested a shotgun mic. Those who use it will probably not be the most video savvy, so that is something to keep in mind as well - but we don't want to dumb it down too much either.
Upon further research perhaps a hyper cardioid is a better choice, but this might be a one man operation for a good amount of shoots - so perhaps the lapel mic is the best bet?
I would be grateful if you guys could recommend some set-ups in the following price ranges, including camera/mic/tripod - $1,500, $2,000, $2,500. We will be outsourcing some of the editing, if that makes a difference. If you have any suggestions (i.e. if you think I need more than one type of mic), please feel free to throw them out there.
Thank you,
Sabin
I would be concerned with Bluetooth if audio quality is a concern. UHF with a 3.5mm plugin would be a better option in my opinion. Sennheiser makes good versions. If the people using it aren't tech savvy, don't let them use a shotgun or any directional mic. They are best on a boom pole with a dedicated mic operator. A camera-mounted shotgun is an option if the camera operator can monitor his or her sound levels while recording. I have seen amateurs try to handhold a Sennheiser 416 we had, and they try to hold it out about 6 inches in front of them, completely vertical, and below the jaw - and talk over it. The mic is directional, so it's picking up the sounds bouncing off the ceiling, directly above. Sounds awful when used incorrectly. I would go with the UHF wireless lav and/or handheld dynamic mic like this
http://www.amazon.com/Rode-REPORTER-Omnidirectional-Interview-Microphone/dp/B00B0Y59XS/ref=pd_sim_sbs_MI_2?ie=UTF8&refRID=08GRT0HVZAWZTENJJHPS
http://www.amazon.com/Sennheiser-Wireless-Microphone-Interviews-Broadcasting/dp/B00EUBGHJ8/ref=sr_1_sc_9?s=musical-instruments&ie=UTF8&qid=1396539461&sr=1-9-spell&keywords=senheisser+wireless+handheld+mic
I'd also be concerned about using a DSLR in your situation. If you simply want the larger sensor but want an ergonomic camera that people will get good quality video from, check out the Sony CX900 HD and the Sony AX100 4K cameras.
I agree with Chevypower here. If sound is important for your interviews and events, and the people using the camera aren't video savvy, I recommend a camera with a mic input (which the A6000 lacks), the Sennheiser UHF wireless plus a good on-camera shotgun as a backup.
If you're recording events, you will also want to make sure to buy a camera that can record for over 30 minutes continuously - DSLRs and Sony mirrorless cameras are limited to 12 to 30 minutes of continuous recording before they have to be restarted.
That said, here are my recommendations:
$1500+ package
Camera: Panasonic G6 - about $650
Fast lens for indoors: Olympus 45mm f1.8 - about $360
Camera mounted wireless mic w 3.5mm jack: Sennheiser G3 - about $630
Pistol grip with trigger to make it easier to handle the camera: Rainbowimaging pistol grip - $23
Remote control cable to connect the trigger to the camera: Pixel CL-RS1 - $7.50
$2000 package - same camera and wireless mic, but now it's time to add:
Shotgun mic: Sennheiser MKE600 - about $330
Shock mount: Polaroid - about $15
XLR to 3.5mm adapter: Hosa MIT-156 - less than $20
$2500 package - time to get a large sensor camcorder and avoid the hassle of changing lenses:
Camera: Sony HDR-CX900 - about $1500
Shoe adapter: Sony Multi-Interface Shoe to Universal Shoe adapter - about $30
Hope this is helpful!
Bill
Hybrid Camera Revolution
Discussion Starter · #7 ·
Originally Posted by jogiba  /t/1525568/dslr-camcorder-for-work#post_24564098
EOSHD review :
http://www.eoshd.com/content/12428/surprise-sony-alpha-a6000-video-mode-huge-improvement
Thanks for the suggestion! How well would the included 16-55mm f3.5-5.6 lens perform with indoor events/interviews? This is looking like a very good option as it seems simple enough, is good for both video and photography, and has that wireless mic attachment. I believe bluetooth would be good enough for our uses --- but can you comment as to if there is wired options in case of interference with this camera? Is there a non-bluetooth wireless attachment? Also, would the onboard mics do in a pinch? Thanks!
Originally Posted by Chevypower  /t/1525568/dslr-camcorder-for-work#post_24564126
Thank you! My company likes the idea of a SLR and Video Camera in one. This may sound backwards, but they would be willing to spend more on a SLR than a camcorder. My limit for a camcorder is probably $1000ish, maybe a little bit more - and these guys have given pretty good options for the $1,500 SLR range. Can you explain why you recommend a camcorder over an SLR for my case? Is there anything worth looking at for around $1000?
$1500+ package
Bill
Wow, thank you. I appreciate all of the time you put into those lists. I have a few questions. First, how well would the Panasonic G6 shoot indoor video with just the kit lens? I don't know if I can sell the idea of a $630 fixed lens to the person in charge. Also, do you know how long you can continuously record with it?
Second, can you recommend a wired mic in case there is wireless interference in the area at the time, or should that be ok all around? I will try to sell the idea of a $630 wireless system, but it will be hard. We're coming from a $60 wired lav mic which they are sort-of happy with (but the cord is too show). Any less expensive options, either wired or wireless?
1. DSLR biggest expense is getting lenses that make it worth having a DSLR. Kit lenses on DSLRs have little benefit over a very good point and shoot. You are not going to get camera and enough suitable lenses for $1000
2. Any advantage that a DSLR previously had for shooting video (large sensor/low light/bokeh) is negated by newer camcorders with relatively large sensors. Honestly, the CX900 and AX100 produce videos that appear as if they were shot with a DSLR or cinematic camera. But you have a built in zoom lens.
3. Ergonomics. You are restricted to manual zoom with no lever. If you need to zoom while recording (which should be avoided anyway, but sometimes it is necessary), it's going to look bad.
Only go with a DSLR if:
1. Still photography is the PRIMARY use.
2. You are prepared to invest in lenses, lights, and other accessories to make your photos and videos stand out.
3. You are prepared to spend the necessary time to master the art.
Discussion Starter · #9 ·
Originally Posted by Chevypower  /t/1525568/dslr-camcorder-for-work#post_24592901
Thank you Chevy. Good food for thought. Is there anything less expensive than a CX900 worth a look?
Also, the more I talk to them, the more I feel that the video taking abilities are mostly for interview situations, and the photography will be for events. An event just sounds too complicated for someone who knows little about video production to accomplish.
If you step down to the CX430, you will go from the big 1'' sensor to just a 1/4.'' The PJ790 has a 1/3'' but it's the same price as the CX900, you are paying for a built-in projector.
Discussion Starter · #11 ·
Originally Posted by Chevypower  /t/1525568/dslr-camcorder-for-work#post_24593836
Thank you!
Discussion Starter · #12 ·
A new challenger!! (Sorry, I have Streetfighter in my head.)
Any thoughts on the BMPCC in relation to other suggestions here?
Also, the time to purchase is coming down on me - so I'd like to get someone's view on video quality of the Panasonic G6 vs. the Sony A6000. I've tried to find comparisons to no avail... probably because they are from different years. Either way, they are similarly prices, so does anyone have any thoughts?
Fantastic camera, but not for everyone. It can give you an Arri Alexa level image in many instances. Throw on a speedbooster and you have a near Super 35mm crop that becomes an equivalent to 2,500 Native ISO with the added 1 2/3rd stops of light added by the speedbooster.
If you decide to go the BMPCC route you'll need IR cut filter and ND filters unless you don't mind stopping your lenses way down out in daylight. You can do amazing things with RAW and Resolve that you simply can't with most video or you can get great ProRes video and simply apply a pre-made 3D Lut for the great or a starting point grade. You get that extra dynamic range to protect more highlights and dark details. You can adjust exposure in post. Post workflow has a bit of a learning curve, but nothing you can't get the hang of with a little practice. The BMPCC is a post workflow camera. If you want a camera that you shoot moving images and then you're done and ready to upload then the BMPCC is not the camera you want. It's a post production camera the same way film and digital cinema cameras are.
Discussion Starter · #14 ·
Thanks MT. While we will be sending the footage out for editing, I doubt they want anything that will require too much work, so that answers my question pretty well. I appreciate it.
My mindset on the other options thus far is....
A6000 vs. G6
A6000 will be more simplistic, while the G6 will allow better quality-to-price audio options. But in terms of video quality, both are great. I'm submitting my recommendations soon. I also added the CX900, but don't think they will go for it unfortunately.
Discussion Starter · #15 ·
Any last words of wisdom before I take the plunge?
Discussion Starter · #19 ·
Originally Posted by brunerww  /t/1525568/dslr-camcorder-for-work#post_24616057
Hi Sabin - You may find it helpful to take a look at some of the videos posted on the Panasonic G6 group that I moderate over on Vimeo:
http://vimeo.com/groups/dmcg6
Best,
Bill
Thanks Bill. I got the A-OK to order the G6. Do you think the kit lens will be OK for a start?
Congrats! the kit lens is great for outdoors, but it's a little slow for indoors - and I presume that your interviews and fundraising dinners are indoors?
If so, the least expensive fast, autofocusing glass you can buy is the ~$316 Olympus 45mm f1.8 . On a tripod, this will be a great event or interview lens.
Again, hope this is helpful!
Bill
1 - 20 of 26 Posts
