Status
Not open for further replies.
1 - 2 of 2 Posts
I am looking for a DSS Receiver that has very fast serial port control. Currently with the 4504 I figured the channel change delay using serial port is (5 sec for ReplayTV buffer + 2 sec for DSS receiver).
I am trying to eliminate the 2 sec DSS receiver serial control delay.
Also regarding the ReplayTV buffer delay, can this be fixed?. The old Showstopper did not have this much delay.
Thanks...
Where'd you get the information that it takes 5 seconds for the Replay + 2 for the receiver?
Since (as far as I know) all the Replay needs to do is spend a few milliseconds to send out the channel change request, that should be done first and the channel should be changed well before the Replay has dumped it's buffer and started re-buffering the signal.
Also, there is a rumor speculating that SB is going to fix the channel changing delay in the next software release.
1 - 2 of 2 Posts
Status
