Status
Not open for further replies.
1 - 4 of 4 Posts
I hooked up the vcr via s-video and audio cables and all i get is sound.. no picture
also bypassed the vcr to see if it was a vcr issue and still no picture
works fine with component cables
any deeply appreciated
thanks
Erick
I don't know the specifics for the Toshiba unit, but the current STBs can't output a HD and SD signal at the same time. Somewhere you have to be able to tell the STB to change to SD which will output a signal via s-video to your VCR. I use the DTC-100 which allows you to change via remote. I assume there is something similar for the Toshiba. You get sound from both outputs at the same time so you get sound on the VCR, just no the picture. You get a picture via component cable because the STB is outputting HD.
SMK
Discussion Starter · #3 ·
I hooked up the vcr via video 1 input
I get sound but no picture
very odd.. i tried to bypass the vcr completly and hooked up the svideo direclty into video 1 input still no picture
Its gotta be a setting in the dst-3000 setup
thanks
Erick
1 - 4 of 4 Posts
Status
