Status
Not open for further replies.
1 - 3 of 3 Posts
Discussion Starter #1
I've tried a search on this and couldn't find anything, so here goes a query. I have a Toshiba DST3000 and I want to connect an outside antenna and a HD Cable box to the STB but can't see how looking carefully at the manual. On the back you have a Sat. input, which I don't need, and an antenna input. The manual indicates that the antenna input will handle either an OTA or a cable. So does anybody know what to do.
Thanks in advance for someone's help.
Hugh Campbell
If you go into the installation menu and and find Local area. You then have the option of configuring where you want your cable, and antenna to connect to. They are called local1 and Local 2.
You need to use local 2 for the OTA
1 - 3 of 3 Posts
Status
