Status
Not open for further replies.
1 - 3 of 3 Posts
I just got a replacement DST3000 back from Toshiba. Its a new unit. I kept the remote from the one I sent back. Unfortunately the new unit wont recognize the old remote. Any suggestions?
You've probably tried this already, but in the spirit of trying to be helpful:
Have you made sure to hit the "SAT" button at the top before doing anything? When first setting up my DST-3000, I had hit one of the other buttons, which put it in another mode and the unit wouldn't respond to the remote. Again, I'm not trying to offend here, just a shot in the dark.
Otherwise, I have no clue what it would be. I wouldn't think they would change remote codes even between different models (almost all RCA models use the same codes), much less in different versions of the same model.
-Jason
1 - 3 of 3 Posts
Status
