Status
Not open for further replies.
1 - 5 of 5 Posts
I have a first generation, Mitsubishi VS-50800, which I hooked up to the DTC*100 using a VGA to BNC cable. I am using it with Directtv and am unable to get a picture at all, I just get a message "No video signal detected". I have tested the DTC-100 with a computer monitor, and am receiving a picture. What am I doing wrong? Is there an activation for this input? I'd really appreciate some help.
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
I think you have to go into the Mitsu menu and tell it to look at the RGBHV signal.
This has been discussed here before, try a search with your model number & DTC.
"better living thru modern expensive electronics"
tm
Discussion Starter · #5 ·
Thanks. Finally got the picture (although small) Now if I can center it, and get some sound to the picture-I'm using a Denon 3200, I'll be in business, but I have a picture for the first time.
1 - 5 of 5 Posts
Status
