Status
Not open for further replies.
1 - 3 of 3 Posts
Banned
Quite well actually.
24" is pretty small for HDTV but that monitor has a very
sharp picture.
On my Sony W900 (precursor to the FW900) I had to
use the front panel controls to shrink the picture a bit
(leaving about a 10% black border around the image)
before the interlacing worked properly.
PVR,
I was too looking for a small but good PC monitor for hdtv.
I can not afford the FW900 cose that would be my first choice obviously.
I heard interlacing problems too with the W900 at 1080i. Did it really fix it by shrinking the image with the monitors controls?
How much picture did you loose in viewable size diagonally?
It says image size is 22.5 diag so when you shrinked it down how much did you lost altogether? Is it now to 20" viewable.
Cose if it's so, I'am still trying to figure out what is the best purchase. The screen size doesn't matter even if it's a 20inch pc monitor but it's sharpness has to be top notch for hdtv content!
BTW, what is the non hd content looking like on that W900?
Bluesting
1 - 3 of 3 Posts
Status
