Status
Not open for further replies.
1 - 2 of 2 Posts
I'm currently using the Theater Master SL-9000 with the RCA DTC-100 and a Philips 60PP9701. Is there any way of turning on or off the HD connection function through a remote without having to press the 'HD' button on the face of the DTC?
I use a One For All (OFA) Cinema 7 universal remote for my DTC-100.
Radio Shack remotes also use the same codes.
OFA advanced codes for the RCA DTC-100 are found at ...
http://www.hifi-remote.com/ofa/codes2/sat_0566.shtml
Advanced (discrete) code 078 turns HD off.
Advanced (discrete) code 094 turns HD on.
Advanced code 026 toggles HD on and off (like the button on the unit).
I'm not sure how these map to your remote, but I use all three on my remote.
1 - 2 of 2 Posts
Status
