Status
Not open for further replies.
1 - 2 of 2 Posts
Hi all. I decided to take the HD plunge this morning, and picked up an RCA DTC-100. I connected my cable to ANT-A, OTA Antenna to ANT-B and my other LNB to the Sattelite antenna. I first checked the box out via the SVideo connector, and all was fine. I then connected the DTC-100 to the RCA Transcoder via VGA and plugged the Y PR PB cables to Component-2 on the 46807. When I press the HD monitor on the DTC-100, the screen on the component input changes from black to blue, but I get no picture. I know the connector works, since that is the one I originally had my iscan pro hooked up to (I moved that to Component-1). Is there anything else I need to do to get the 1080 signal to show up?
-Michael
Banned
Sounds like you have it all figured out.
You should be able to gets some menus (using the remote)
even if you are not receiving a signal.
Note: The DTC100 outputs 540p unless you are receiving an HDTV source, so perhaps your transcoder or display has a problem with 540p???
If you have subscribed to DirecTV HBO you can try that on channel 509 for 1080i.
1 - 2 of 2 Posts
Status
