Status
Not open for further replies.
1 - 5 of 5 Posts
Originally posted by del:
I am getting channel 400 (sat 119?).B]
Is this channel in English or Spanish? If you are correctly receiving the 119 satellite it will be in Spanish.
To make sure you are ok on 119 bird I would hook the coax straight to the DTC100. Make sure you can get NASSA channel, 509, 119, & the 400's spanish. Then put your switch back in. Just eliminate all the potential trouble spots.
I bought a open box dtc at bb. I ordered the 12 HBO ala cart and unable to get 509 or Hdnet 199. 509 has a message of not available in your area. Hdnet has a message call to order. Directv has sent me a new card same problem. I have two 18" dishes the csr said you must have an oval dish. I told her many of my fellow AVS brothers have the two 18" setup. I am getting channel 400 (sat 119?). Anybody ever have a similar problem? I think the DTC 100 or the switch is bad.
1 - 5 of 5 Posts
Status
