Status
Not open for further replies.
1 - 2 of 2 Posts
Looking for someone using the Radio Shack 1994 remote with the DTC-100 that has these
( http://www.hifi-remote.com/ofa/codes2/sat_0566.shtml ) discrete codes working for toggling aspect settings. Here in SoFla we now have a whole 2 stations broadcasting in HD and its getting to be a real chore to wade through the menus to switch from 4:3 & 16:9 with every channel change due to the conficting way these 2 stations broadcast. I can only get 1 code to work for toggling the HD on off. Thanks in advance.
Frank:
If the stations are broadcasting up-converted 4:3 material with side-curtains, you're out of luck. The DTC-100 will only change aspect ratios on "true" 4:3 material not on 16:9 1080i up-converts. If the stations are broadcasting 480p (such as FOX), then you can do it. Check www.remotecentral.com for the codes.
BOYCOTT DVI/HDCP & JVC!
1 - 2 of 2 Posts
Status
