Status
Not open for further replies.
1 - 3 of 3 Posts
DTC-100 is hooked up to Input A on 10 HT with a 40' VGA cable, Input A is set to DTV GBR (I have tried all four settings on Input A), When an HDTV siganal is apparent on s-video from DTC and I switch the DCT to HD using the front button I get no hint of a signal to 10 HT.
Input A works fine with a DVD component input and I have good antenna signal strenght. DTC is not subscribed to DTV, using for terrestial only.
Any and all advice greatly appreciated.
When viewing a nonHD source on the DTC-100 IT WILL output 540P which the 10HT will not accept. Put the DTC-100 on the HD demo ch 199. The change the input settings on the 10HT and for use of RGBHV.
Kind of a pain but to watch Satellite (nonHD) you would need to run S-video or composite to the projector.
I have another one of these combos to finish tweaking later this week. If someone else knows a better way I'll all ears.
Dave
Watch HDTV!!! Nothing else comes close!
[This message has been edited by David Richardson (edited 05-29-2001).]
1 - 3 of 3 Posts
Status
