Status
Not open for further replies.
1 - 4 of 4 Posts
The installers are here as I write this. I have channel 509 working and producing a lovely hidef picture through my rca dtc100, however, I get no audio. My receiver doesn't have any room for another optical connection, so I have the audio running through the analog rca jacks. I get audio on SD channels, but when I switch the dtc100 to hidef I get nothing. Does the dtc100 put out digital audio only in hidef mode, or is there a setting I need to adjust?
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
It will output analog audio from all sources, when in HD or standard mode. Your unit may have a problem.
"Better living thru modern, expensive electronics devices"
tm
Discussion Starter · #4 ·
Fixed it, like a dummy I forgot the audio was going through my standalone TiVo which of course was not passing through audio because it couldn't process the hidef signal.
1 - 4 of 4 Posts
Status
