Status
Not open for further replies.
1 - 3 of 3 Posts
From what I've read, all you need to connect your dtc100 (or HTPC) VGA port to the Mits is a BNC5 cable, because the Mits has RGBHV. What about my Toshiba 61H70, which only has RGB component, no HV part? Do I need an RCA converter box RCA VHDC-300, or can use the cable and ignore the HV part?
You will need the transcoder that changes RGBHV (VGA) to Hi-Band Component. Either the RCA or the Audio Authority unit will work. www.audioauthority.com is wherre you can order their transcoder.
The Mits accepts RGBHV while your Toshiba does not.
Lee
[This message has been edited by LeeAntin (edited 04-04-2001).]
1 - 3 of 3 Posts
Status
