Hi MarcW,
I am a DTC-100 and PRO-510HD owner as well. While I don't get CBS in HD, I do receive PBS, occasionally ABC, HDnet and HBO in high-def. From your description, I don't think you have any equipment or configuration problems. Most likely what you are seeing is that advertisements, even on HD broadcasts, are not produced for HD in the 16:9 aspcect ratio. Most ads are in 4:3 and the black bars are added by the broadcaster to properly "fill out" your 16:9 display. Hope this info helps!
StanleyCat
StanleyCat
