Status
Not open for further replies.
1 - 3 of 3 Posts
Since recently setting up the DTC100 I have noticed the DirecTv guide takes quite a bit of time showing the listings - when guide is first pressed the shows are listed but if I arrow over 1 screen I get "acquiring information" and it takes a bit of time before anything appears in each grid block. All our other D boxes display the guide info for at least a week in advance (UTV longer) but not the DTC100 - is this the way the guide in this unit works?
I've had my DTC100 for a couple of years now and used to have a good 12 hours worth of guide info.I used to use the "theme" search function to see what was going to be on that evening,but it's totally useless now.Don't really remember when they started "shorting" the guide info.Maybe on the last upgrade or they just changed the way they send it.
1 - 3 of 3 Posts
Status
