Status
Not open for further replies.
1 - 5 of 5 Posts
Before I "fork over a fortune and a half" on a new Pioneer VSX-47TX I was wandering if anybody could answer the following 2 question?
My HTPC uses an Audigy Platinum card. Will the card pass both DD and DTS signals to the receiver for decoding?
My MOBO is an ASUS A7V-266E. It looks that my "Italian" connection may be able to get me the daughter board (i.e. S/PDIF-out Module) for the above MOBO. Assuming the answer to the first question is affirmative, which of the 2 (i.e. Audigy vs ASUS) will yield the best results?
Renato
I use an original SB-live platinum with my A7v-266E and it works ok. The onboard 6 channel audio (havn't tried any add-on to get SP/DIF, didn't know it existed) is terrible. The SB Live is 'ok' but my M-audio card in my HCPC is so much better! I've relegated my Creative card to gaming stuff only.
Discussion Starter · #4 ·
I am using my Audigy platinum optical out only to connect to a DD/DTS receiver.
Ok, if the SPDIF of an audio card is used, why would it make any difference which card one would use (i.e. M-audio, Audigy, Fortissimo etc)? Isn't the SPDIF just "passing thru" the signal? Are we saying that one card "passes" the signal better that an other?
TIA for the clarification
Renato
Quote :
nutcase,
What do you mean by better ?
Does M-audio spdif quality is so impressing compare with SB Live! ???
What do you use for the test? CD-Audio or DVD?
Share us your system detail.
Ciao,
:cool:
1 - 5 of 5 Posts
Status
