1 - 2 of 2 Posts
· Registered
If I use Win DVD 8 and a Prelude 7.1 soundcard, am I getting DTS HD Master Audio if I select it from the dvd menu or is the sound track is DTS Core only? I am using the analog outputs on the Prelude 7.1
Thanks in advance
Shammer 3
· Registered
it is DTS-HD MA, which is resampled to 16bit 48khz or analog output.
DTS core is 16/48khz but compressed, so you are getting uncompressed but possibly (only if greater the 16/48) downsampled audio.
1 - 2 of 2 Posts
