1 - 3 of 3 Posts
Hi!
I wonder if a Intel P4 with MK ASUS P4P800-SE and a built in card supports DTS? if there is a digital out for sound?
Or is it a question of getting the right codec..? (for all cards)
Thank's!
The H55 motherboards with a Core i3/i5 Clarksdale CPU most definitely do DTS. Gotta have the right codecs though which all depends on your version of Windows, file type and what player you are using.
Mostly it is a question of the having the right decoder for core DTS. If your asking about HD audio, then you will need the proper hardware. If you have a TOSlink or Coaxial Audio out on your PC then core DTS should play fine.
1 - 3 of 3 Posts
