Originally Posted by
pupsin /forum/post/18212616
I'm running Windows 7 with Intel Audio Studio, with
this motherboard . Intel Audio Studio is powered by Sigmatel and my sound card is on my mobo.
EDIT: My video card is a ASUS 9400GT with HDMI. Although it has hdmi audio out, you need a internal SPDIF port which I don't have.
Is this a home build or a Dell or something. A lot depends on the motherboard, not the chip set. Is it a Gigabyte, ASUS, MSI. Use
this program and it will tell you exactly whats inside your computer. You might need to do one of two things if your onboard is crap, which they usually are. Get an ATI 5000 series GPU, or a discrete sound card. Also, go to the Nvidia web site and make sure you have the latest drivers for that card, both audio and video.
Ok, once you know what your mother board is, exactly, go to that site and make sure you have all the drivers installed for that board. There will be a driver specifically for audio that you will need to install so you can tweak your system. Like your sampling rate, speaker set up, bit streaming, and what port are you using.
