Status
Not open for further replies.
1 - 2 of 2 Posts
I am waiting for the installation of DirectWAY (a two ways access the internet using the same oval 24x38" satelite; addional LNB is needed for DirectTV) However, additional satelite is needed for HD signal. I have the DST3000. Any insight on this setting would be appreciated!
DirectWAY = $579
additional disc w/ std receiver= $29
You're gonna need another dish no matter how you do it. The PC dish is not the same as the HD Oval. The PC dish is alot bigger (if it is still the same as when I had DirecPC). It's only designed for the 110 bird. I would pass on the Duo PC system and get the HD Oval + the PC only dish. Or you could get a round and aim it at the 119. However, if you need the 110 bird sometime your gonna need another dish.
Ken B.
1 - 2 of 2 Posts
Status
