41 - 49 of 49 Posts
I have always been intrigued by the sonosub. This build has me thinking :unsure:
It is quite different when they actually look good, Mine were just wrapped in fabric. My first build was never covered and ugly as hell. If I did not build an IB I would build sonos again. So simple and light weight.
Discussion Starter #45
Made some more progress. Spraying duratex went amazingly well this weekend. I鈥檝e got the ring around the top sub done and the bottoms of the caps are done.
3080182
3080186
Also spent some time getting all of the legs perfectly square and matched to each other.
3080187
And the Speakon is wired up.
3080189
I really like how the veneer turned out on that!
Btw what is that 8awg wire going to the speakon :oops:? Use any special terminals or just generic female quick disconnects?
Edit: Probably just the in wall insulation throwing me off.
Discussion Starter #48
Thanks! Nothing funny with the wiring. It鈥檚 just 12 gauge OFC in wall rated. I soldered to the Speakon terminals and added individual shrink tubing to each wire then added a larger shrink tubing for each pair.
Discussion Starter #49
Here鈥檚 what I decided on for the final profile of the legs, for the top sub anyway. You can see what I drew on the blue tape. The cap will sit down in there.
3080623
Also experimented with a few stain samples. I鈥檓 not crazy about any of them. I might have to stop at Woodcraft this week.
3080625
Here鈥檚 natural with Osmo:
3080626
41 - 49 of 49 Posts
