1 - 9 of 9 Posts
Here is where I am currently with my design and I feel fairly comfortable with the numbers. This was calculated with WinISD.
SPEC:
Dual ACI SV10s
Passive Vented Design, with front/back opposed drivers, port also on back.
Enclosure of 2.85 cubic feet.
I will likely be using polyfill to get an effective 25% size increase.
Port will be 4" Diameter at 41.5" long.
Drivers, bracing and port are roughly .45 cubic feet.
This should result in a 3.0 cubic foot enclosure tuned between 16-18Hz.
I will have two of these.
This will ultimately be EQ'd.
At MAX POWER for the drivers (500 Watts for two), I get...
SPL:
94 dB at 10 Hz
106.6 at 20 Hz
111 at 30 Hz
112.6 at 40 Hz
113 at 50 Hz (with 1 dB up from there)
GROUP DELAY:
15.2 ms at 20 Hz
9.8 ms at 30 Hz
6 ms at 40 Hz
4 ms @ 50 Hz (drop from there)
PORT AIR SPEED: (I will have large flares on the ports)
19.6 m/s at 20 Hz
9.7 m/s at 30 Hz (continues to drop)
DRIVER EXCURSION:
XMax + 10%
Any thoughts/improvements on the design are welcome, but I think this should give a great result in not much space. Hopefully when combined with room gain and the equalizer, it will give quite the quality bang for the buck.
Agree? Disagree?
Thoughts? Increase box size so you can decrease port length. And for ported enclosures, you usually don't get more than a 20% increase with fill. Also, fill tends to negate the effect of the port.
As Looney said, port length is too long which will result in a nasty resonance in the passband. With the rear faceing woofer/port you'll have to place it far enough off the wall to avoid port compression. I'd side fire them with a front mounted port. I've built designs who's port speed reached 35 m/sec with absolutely no audible effects so if you need to drop the diameter to 3" to reduce the length i wouldn't worry. A front mounted slot port would work nicely as well.
A single 3 inch port sounds a bit small. Of course its tuned low so the effects, if any, will be heard only during low hitting scenes. I had a single piece of junk rca 10" subwoofer driven by 120 watts and I got chuffing from it. Got a lot of other things too, but chuffing I had. I figured it was tuned in the mid 30's though so I am sure that had something to do with it. It had a 3 inch flared port.
Are you dead set on those drivers? You may get better results with a single larger driver.
Discussion Starter · #6 ·
Port resonance is at 163Hz. Is that too low if I plan on crossing at 100Hz?
I may be going a little larger with my enclosure, or I may go with a smaller sealed. Am I locked into these drivers? No, but those are the ones I got a great deal on. I am open to other drivers, but I feel I have modeled almost anything out there and these are certainly a good bang for the buck.
163hz and XO at 100hz? That's not even one octave. If it was me, I'd keep my 1st port res a minimum of 1octave away, so >200hz. That would likely mean a bit bigger enclosure and/or a higher tuning point. Or, beefy enough mains to handle a lower XO point of say 70-80hz.
You will hear chuffing with a 3 inch port, particularly with the low tuning you are looking at. If you are using a BFD to tame your room, you can add a notch at the problem frequency for the port.
You want a clear path from the driver to the port, so lining the box to catch resonances, rather than using stuffing is the way to go.
Discussion Starter · #9 ·
I am currently trying to decide if I should just do a dual sealed design, or use a passive radiator instead of port. I get a fairly good response with CSS's 15" passive. I also like the fact that you can tune it after the box is built. It is more $, but saves a lot of the trouble of port design.
1 - 9 of 9 Posts
