Ok here it goes!
I bought new Terk Oval with triple LNB but it did not work due to obstruction.
Went with dual oval dish, dual lnb option dish 1 pointing at SAT 101 and dish 2 pointing at SAT 119. I am now able to get very good signal on both birds.
I was adviced to get the best SPAUN SMS 5400 multiswitch for best HDTV solution. It has 5 inputs 2 for SAT A, 2 for SAT B, and one for off the air.
When I connect the two SAT B (119) to the switch I get good signal and picture, but when I cannect either (101) lead to to SAT A I get no signal on both or only every other transponder on SAT A.
I've tried very configuration possible. Nothing works. Individually they work fine with great signal!
Pelase help
Pelase help
