Status
Not open for further replies.
1 - 6 of 6 Posts
I have a replay PV-HS2000 that I upgraded to a dual drive system. It has the org. Quantum 30 gig drive along with a WD 60g 5400. The WD is dead...... Before the WD died I made a back up of both drives..... My question is am I screwed??? Any help would be greatly appreciated:)
Well your unwatched shows are likely gone, but it should be rather simple to revive your Showstopper.
Just use RTVPatch once again to restore your backup image onto a new drive, and then patch. Simple as that.
And this time I'd use a single large drive... give yourself better odds. :)
Actually if it was Drive One you can probably just repatch it now (without a restore) and use it as a 30. But I'd get a new drive while you are @ it. As you see, hdd lifespan is comparatively short in a PVR.
Otherwise you don't really need to zero the 30.
Originally posted by murph3186
...Now I need to buy a lager drive... Any recommendations??
Rheingold, Drax, Lighthouse?
Moosehead... if you want smooth smooth smooth?
However don't drink-n-drive. ;)
(hdd's for the Showstopper... about any drive bargain--rebate--deal often posted here, Western Digital or Maxtor... go for 5400 RPM if you can find it, but 7400 will work, so try for the better price)
1 - 6 of 6 Posts
Status
