21 - 22 of 22 Posts
Do you think I would hear a noticeable difference in output if I went for 2x dual vbss cabinets? My room is about 15L x12W x8H
Oh, absolutely! You're doubling the surface area and number of cones in the setup. And as I mentioned, running 2 pair lets you run a 4ohm load to the amp on both channels, effectively increasing the power to the drivers. Otherwise with just a pair of VBSS, you are either running each driver at 8ohms (n) or running the pair in parallel for 4ohms, but only running a single channel on the amp.
Plus, a dual VBSS would just look awesome.
I have a question about just that, sorry about the thread hijack but since it was brought up...Would it be better to run a single vbss at 8 ohms on each channel or run one channel at 4 ohms with 2 vbss wired to it. (Nx3000d)
21 - 22 of 22 Posts
