1 - 5 of 5 Posts
I have a dish network VIP722 in dual mode but only have 1 cable running down the wall. I was wonder if it is possible to take the output to TV2 coax and run it back through the input cable and then splice it to TV2.
I have attached an image to hopefully help in what I'm trying to do.
Yes, you need a coax diplexer. A google search should find what you are looking for.
Ted
Originally Posted by MagnumVP /forum/post/17019764
So if I get a DiPlexer for both the [1:2] boxes in the diagram I attached, then it should work? Any particular Diplexer I should be looking for?
Yes. Perhaps someone with installation experience could recommend one, but I think it would just have to be DBS compatible.
Ted
1 - 5 of 5 Posts
