I need some help to set up a dual display with MyHD card on my PC.
I have a 9800Pro that I'd like to connect to my monitor (sony 19") and my Mits 55". I'd use the monitor as the primary display and would connect it via VGA. For the Mits, I would use a dvi -> vga adaptor, connect to MyHD, and connect to my Mits via RGBHV (connection #1 on this link: http://www.digitalconnection.com/Support/cn_myhd8.asp ). This way, I would have dual monitor, outputting extended desktop plus MyHD to my Mits.
Is this even possible to do? Do I need hydravision (or ultramon) to run the dual display? I'd like to use some custom resolutions on my Mits, so I assume I need powerstrip to set up the timings. Is powerstrip capable of using different resolutions/timings for two displays, while running extended desktop? Can powerstrip work together with hydravision?
Last question. Assuming all this is possible, what happens when I start MyHD on the secondary display (Mits) and I go to full screen mode (1080i)? Would this freeze my mouse and keyboard on the primary display? Does MyHD support dual display with extended desktop?
Thanks in advance!
Thanks in advance!
