Using Vista I'm looking to send sound out of the Realtek HDMI and the Creative X-Fi Xtreme Audio SPDIF output at the same time in order to send sound to 2 amps simultaneously. Goal is to have my main PC be the source for a whole house a/v system powered by 2 amps.
Set up will be: computer in basement with DVI to monitor and SPDIF to basement amp power a 3.1 (no rear surround in basement, just 2 fronts, a center, and a sub) speaker set up. Basement amp will also power 2 speakers in exercise room via secondary (b) speaker channel. Will have HDMI running from basement computer up to main amp in living room. Using a cloned screen set up, so by switching a channel on the upstairs amp, will be able to see desktop screen. The HDMI will power 5.1 speaker set up and then secondary channel to outside. Will use Gyration LCD remote http://www.provantage.com/gyration-g...s~7GYRA14H.htm that uses RF to control computer.
Would love to have the option to use this set up to either have sound play out both outputs simulaneously or even better would be to have the choice to play separate audio streams.
Let me know your thoughts.
