The knob that says "level" (min-max) controls volume. Adjust it until the subwoofer volume is at your preferred listening level. If you have a disc with test tones and a SPL meter, you can dial in your sub's volume more accurately, but doing it by ear should be ok.
The switch that says "normal" and "reverse" controls phase. I'd leave it at "normal", listen to some bass-heavy music for a little bit, then set it to "reverse" without changing anything else, and listen to the same stuff again. Whichever setting gives more bass output is the correct setting.
The "cut off" knob is your sub's internal crossover. It tells the subwoofer what frequencies to play up to before it stops and lets the other speakers take over. If you're connecting the subwoofer with an RCA cable to your receiver's "sub" output, just turn this knob to 200hz, or if there's a way to turn off the crossover, do that. The receiver will set the crossover frequency for you. If you're connecting your speakers with speaker wire to the subwoofer, find a point at which the crossover frequency makes the subwoofer and other speakers blend together well and sound balanced.
This is just a very basic explanation. If you need or want more assistance, I'm sure many people here will be ecstatic to smother you with technical details
. Good luck.
Stephen
Stephen
