4:3 it's correct if you use MKV or other media files, but it seems to be still wrong if you want to play a DVD ISO. There you have to switch the format to 4:3 after you've started it.Does this Dune player handle 4:3 correctly? This is important to me. I play a lot of 3D blu-rays and 4k/HDR, but I still have a lot of DVD content also.
yes..4:3 works perfectlyBut does switching it to 4:3 manually actually display it correctly in this Dune player? Because with my Zidoo x10, it does not. Even switching manually to 4:3 in the Zidoo aspect ratio settings, it displays both PAL and NTSC 4:3 material incorrectly, for DVDs and also files like mkv. It's always stretched or squished no matter what you do or what display mode you choose. At least if I could manually swicth it and it worked that would be something.
Supposedly the new Zidoo x9s has fixed this issue. Does Dune plan to fix the auto 4:3 switching for DVD folders and ISOs?
Have you done a factory reset?After three days of normal usage, for the first time today, the Dune HD Pro 4K II Plus does not recognize gigabit network. After I plug in the device, the green light comes on and flashes for a few seconds and then goes out and the orange light comes on. On all other devices in the home network, the green light blinks neatly and the devices recognize the gigabit network. Now, content is transferred to Dune at a speed of about 50Mbit and while the device recognized the gigabit network, the content was transferred at a speed of about 100Mbit. Since everything worked for the first three days, I'm interested in whether there is a malfunction on the device or the problem is related to the current firmware. I've tried everything but I can't get the device to recognize a gigabit network
Of course. Not a solutionHave you done a factory reset?
Hi Muad,Not sure if been answered..
Deciding to get this dune..
I want to use emby tv app with Dune.. As I use emby server to scrap movies..
Will dune allow emby app to use dunes awesome internal video player?
I know emby app gives option to use external player...
If so, then awesome... I can use emby for posters etc and dune video player for best sound and video..
Question also..
Dunes built in movie wall app, can you store the database to a Nas (SMB) location instead of using internal storage in dune..
thanks
What are the main bugs in dune that made you decide to get the zidoo?Hi Muad,
Emby works on DUNE, but the resolution still limited to 1080p. Dune's developer said me that they will allow to use dune player as external, but for now, I didn't saw that change in the firmware.
I am very disappointed of the box because it's plenty of bugs. I decided to buy the new Zidoo box.
First, because I cannot use emby (because of the limitation).What are the main bugs in dune that made you decide to get the zidoo?
Thanks for answering emby question..![]()
Is there a way in dune to use Kodi and use the emby add on? and have Kodi use the Dune internal player? like a wrapper function..First, because I cannot use emby (because of the limitation).
I really don't like how Dune manage/show/follow your collection (Emby is much more better):
- emby scan automatically new element added (scan is automatic and give better result) for Dune, you have to run manually indexing (at least, I don't see where I can run it automatically). And sometimes, when it doesn't found correct result, even IMDB id doesn't work.
- you have plenty of way to show your collection, and you can create several profile (for me, I need a different profil for my kids, to show different collection) for Dune, you have less options
The remote is to "sensitive". You have to point on Dune, and not 1 cm next to it, otherwise, it will not detect you.
There is several little bugs annoying. For example, when screensaver start, the default language is overwritten by chinese.
I tried, but for me Kodi dump. I didn't try all versions. But for sure, you will have the same limitation problem (1080p).Is there a way in dune to use Kodi and use the emby add on? and have Kodi use the Dune internal player? like a wrapper function..
I know there is a Kodi wrapper app(xbmc wrapper) for Android that let's you choose external players for Kodi, but will dune player show in list?
If so, then we could use Kodi and Embuary skin
Let's hope they allow internal player soonI tried, but for me Kodi dump. I didn't try all versions. But for sure, you will have the same limitation problem (1080p).
Does the stock player have same quality as dunes internal?You can still choose the stock RTD player though.
Plex doesn’t allow for external player on Android afaik.
