A buddy loaned my his Peavey bass cab a while back (118-SUB HC) which had a single 700W RMS Peavey Black Widow in it. It was probably 15 years old when I got it so my Mackie amp did it in within a year. I was feeding it 1400W RMS (bridged 4ohm) and did it in.
My buddy will let me change out the speaker but I love the cabinet. It's about a 6.5 cubic foot ported box, though I'm thinking of sealing it up for tighter response. I'd like something that can play below 30 hz, I've seen some models that only go to 35 or 40. My Mackie amp crosses it at 63hz, seems a good fit.
What would be a good 18" driver that will work well in a box that volume, and preferably under $400. Also needs to be able to handle the wattage. I was looking at this RCF sub but I don't know anything about RCF or their quality:
http://www.rcfaudio.com/vediMacro.ph...00/product.htm
Thanks all
Thanks all
