I got the Kenwood 5700 and have had good luck so far on my system. Got my first DVD-A disc tonight and it sounds better than the usual CD, but I noticed my receiver (Denon 2801) is not registering it as Dolby Digitial or DTS. The receiver has the 6 required inputs for DVD-Audio. I suspect the connection cables are the problem--I am using Monster Cable Interlink 250's. They have red and white adapters at each end so I am using 3 cables total--I hope that makes sense. Do I need 6 separate monopolar cables to get the Digital signal that I think I should be getting?
Many thanks,
Dan
Many thanks,
Dan
