I just bought the 2005 HBO series ''Unscripted.'' The case says aspect ratio 16:9, not letterbox or anything like that. My bluray player is set to play DVDs in their natural ratio whatever that may be. Even oldies like Uncle Buck play in widescreen with no unnatural cropping if the case says 1:85 or 16x9.
So I put in Unscripted, and the menu is 16x9, no stretching, no cropping. I select an episode and the 4:3 begins. The actual shows are 16:9...inside a 4:3 box. What gives? I own a ton of DVDs and this is the first I've seen of this on my widescreen HDTV.
I have my BD player set to 16:9, not 16:9 FULL, meaning that 4:3 content shows as just that, not stretched. And widescreen material of any aspect ratio is shown as intended, HD or not. This way I always get the intended product.
What usually happens with non HD DVDs that are 16:9 is the menu is 16:9, then the FBI warnings are 4:3, then the movie is 16:9 . With Unscripted, menu 16:9 (truly, not stretched ), then everything proceeding is 4:3 (with main content widescreen stuck inside 4:3 box). WTF?
